Discussion topic: Connecting router to Samsung tv
This message was authored by: ABMCR
Message posted on 03 Jun 2024 08:52 PM
I recently moved from bt broadband and tv to sky broadband and sky stream. Both pucks work fine.on downstairs tvs. I have connected mobile phones, sonos speakers and laptop to the router, no problem. However, both of my upstairs Samsung tvs that I use mainly for apps like netflix etc will not connect to router. They will Both connect to 5g hotspots and I had no problem with old bt router so tvs are OK. Just a problem connecting to sky router. Tried all suggestions of unplugging everything and resetting network on tv. Entering ip adress manually. Bringing tv nearer router etc but nothing works. Any suggestions would be welcome as it's driving me mad. I potentially have two redundant tvs. Thanks in advance.
Find out more
Message posted on 03 Jun 2024 09:40 PM
Re: Connecting router to Samsung tv
Typically the best approach with a television is a network reset and then a new connection using WPS.
Message posted on 03 Jun 2024 11:59 PM
Thanks for your reply.Will try that again.. I did connect it once with wps but after tv was turned off it wouldn't reconnect when turned back on.
