Discussion topic: Connecting a wireless printer to my Sky router
This message was authored by: Shaun73
Have just switched from BT to a full Sky system eg Sky Full Fibre 150, Sky Broadband, Sky talk. Having touble connecting my wireless Canon printer to the sytem. Only currently works if I place the printer right next to the router. Would a sky booster mesh box help and could I instead use a BT Whole House mesh system
Re: Connecting a wireless printer to my Sky router
@Shaun73 As long as it is the BT Whole Home version ie the white round disk's from them then yes use to increase your wireless wi-fi around your property.
Avatar for Shaun73
Many thanks JimM1
@Shaun73 Go for it, the BT site is where you need to be if you come accross any issues, but if you have setup before you should not, just remember that you may need to turn the wireless off on the sky hub if you have your BT master home hub next to it...
