2
This discussion topic has been answered Discussion topic: Connecting a PS5 to Sky wifi
This message was authored by: AWVlogz77
Hi, I am trying to work out where to find lowering my wifi security level to wpa2 but can't find it at all. My ps5 won't connect until I do this and the app hasn't helped at all
Avatar for AWVlogz77
This message was authored by: AWVlogz77 Answer
Re: Connecting a PS5 to Sky wifi
Hello, I had to contact sky and reset the hub as the product wasn't appearing on my sky app. But afterwards the steps you said helped, also forgetting and re logging into the wifi via the ps5 🙂
@AWVlogz77
To change the WiFi security level
  1. Open the My Sky app.
  2. Tap Product Settings on Home or the Broadband tab.
  3. Tap Sky Max Hub.
  4. Tap WiFi Settings then Advanced settings.
  5. Tap WiFi security levels.
  6. Use the Security level drop-down and select either:
    • WPA2 – A lower level of security
    • WPA3 – A higher level of security
    • WPA3-T – The default level of security
7. Tap Save changes.
https://www.sky.com/help/articles/change-wifi-max-hub-settings
