5
This discussion topic has been answered Discussion topic: Connecting Sky q mini box and PS5
This message was authored by: Paisley+Buddies
Looking for guidance.
I have the following set up
Sky router in lounge downstairs
1x Sky Q main box in same lounge downstairs
1x mini box wired via Ethernet cable in other downstairs room
1x mini box wired via Ethernet cable in bedroom upstairs (2 floors up).
I am investing in a PS 5 and would ideally like this wired via Ethernet for best connectivity.
Given that the upstairs room is 2 floors up running and the cables are outside the building, running another cable is infeasible for me to do myself.
Can I simply remove the Ethernet cable from the mini box and plug it into the PS 5 when gaming then revert back to the mini box when watching tv in that room.
Or should I be looking at another option?
From when the sky q was installed I believe one mini is wired to main sky q box, other to router (not sure which is which)
Thanks for helping.
Re: Connecting Sky q mini box and PS5
@Paisley+Buddies You could plug and unplug the ethernet cable but its not recommended as the connectors can break. A better solution is to buy a cheap Unmanaged Ethernet Switch with say 5 ports which costs under £20 (something like this ) which you plug the cable from the router into one port and your devices into any other port on the unit. The switch needs power so you need somewhere to plug its power supply into.
Avatar for Paisley+Buddies
Thanks for that .
i had considered it could be an option but would mean running another cable from the switch to the room 2 floors up, and as current cables go on outside of hose etc had kind of ruled this out as a feasible option to do myself.
I'm glad as a rather non technical person I actually considered the same thing you suggested though 😊
This message was authored by: JPR007
@Paisley+Buddies Using a switch doesn't mean running another cable up the outside, you put the switch at the end of the existing one in the upstairs room with the PS5 and Sky box and its splits there. Then you just need 2 short cables for both devices out of the switch, job done 🙂
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Many thanks @JPR007 & @Chrisee.
I'll see how it goes on Wi-Fi and that'll be my my next port of call 👌
@Paisley+Buddies Anything to do with gaming, always use a cable if its feasible. Wifi is inherently unstable and regularly leads to lag/dropouts 🤓
