Discussion topic: Connect Hive hub to Sky router
Message posted on 30 Oct 2024 12:02 PM
I have recently moved from BT to Sky Broadband. Now my Hive hub will not connect with the router.
Hive blame Sky saying that the ports are not open.
Hive hub requires the following
UDP port 123 (NTP)
TCP port 443 (HTTPS)
TCP 5671 (AMQPS)
Any help would be appreciated.
Message posted on 30 Oct 2024 12:04 PM
Re: Connect Hive hub to Sky router
@Glen19 black or white router from Sky?
Message posted on 30 Oct 2024 12:07 PM
The router is black, only switched over this year. Could be an Sr203?
Message posted on 30 Oct 2024 12:09 PM
@Glen19 You might have to split the Wi-Fi to get the Hive hub to work.
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
