Discussion topic: Connect 3rd Party router to Sky Broadband
Message posted on 06 Aug 2024 09:14 AM
Hello,
I currently have Sky Broadband Superfast (with a NTE5C socket) and would like to connect it to a Zyxel NR5101 router.
I have had a look at other users issues trying to connect and seem to be getting very different responses.
I have enabled the below:
But struggling to understand what info the router needs to connect the broadband
I have seen some forums mention about using option 61 with IAID with the first 8 digits of the MAC address and DUID with "7c4ca5123456" but this does not seem to work
Can anyone tell me what I am doing wrong and if this is the correct way to do it?
Message posted on 06 Aug 2024 10:29 AM
Re: Connect 3rd Party router to Sky Broadband
That appears to be a 5g router for a mobile data sim
You would need a combined dsl modem router or a dsl modem plus a seperate router
Message posted on 06 Aug 2024 10:54 AM
Thanks for the reply.
So to confirm, I would either need a seperate DSL modem to conect the line, then connect to the router?
Or would I need a completely different router that is cable of connecting ADSL/VDSL/FTTC?
Message posted on 06 Aug 2024 11:02 AM
Could you firstly post you hub stats to verify your current connection
Ideally a wifi 6 asus rt ax or asus zenwifi model with a seperate modem bridge or , for example the asus dsl ax82u which combines the modem and router in the same box
Message posted on 06 Aug 2024 11:09 AM
"Ideally a wifi 6 asus rt ax or asus zenwifi model with a seperate modem bridge "
Apologies forgot the add the modem bridge to go for price wise would be the tp link td w9970
Message posted on 07 Aug 2024 09:26 PM
Sorry for the late reply.
So I've changed my router to a Draytek 2865Lac. The line seems to be sycned but looks like I'm missing authentication details.
Can someone let me know what authentication details I need?
Message posted on 07 Aug 2024 09:44 PM - last edited: 07 Aug 2024 09:47 PM
@JackT97 Are you in the UK? as Sky use MER. In which case you need to be using the tab MPoA / Static or Dynamic IP using the settings below:
You also need to populate Option 61 within DHCP Client option as per
My screen has additional WANS as i have a Draytek Vigor 3910, but you should see the DHCP client Option button under WAN --> Internet Access. Make sure you have the correct WAN selected
