Discussion topic: Computer is going slow on WiFi but mobile and sky glass are fine
This message was authored by: Ds93
Recently moved house, and my computer is taking an extremely long time to load and search on the internet via sky broadband, however my 2 mobile devices and sky glass works perfectly. Is my new home the issue? Or can something be done to increase this connectivity. It worked absolutely fine before the move with the same amount of devices connected. Thanks
This message was authored by: PrinzProtato
Re: Computer is going slow on WiFi but mobile and sky glass are fine
That sounds like a browser cache/DNS Lookup issue
you can try flush the DNS on your PC with 'ipconfig/flushdns' on windows
This message was authored by: Melson28
How would you do this on a MAC?
Sorry for the delayed reply
1
Flushing the DNS cache on macOS is a straightforward process that helps resolve connectivity issues and prevent security threats.
Example for macOS 12 (Monterey)
sudo dscacheutil -flushcache; sudo killall -HUP mDNSResponder
