Discussion topic: Chromecast with Google TV keeps disconnecting from WiFi network then reconnects. Help!
This message was authored by: Taipan70
Chromecast with Google TV randomly disconnecting and reconnecting to WiFi network. Dongle is up to date and about 15 other devices do not do this disconnect and reconnect loop. Help!
Re: Chromecast with Google TV keeps disconnecting from WiFi network then reconnects. Help!
@Taipan70
Is your Chromecast behind the TV plugged in? This could be the issue as TVs act as great WiFi blockers
I am NOT a Sky Employee
Avatar for Taipan70
No.  The Chromecast is not behind the TV. It is connected to a Samsung One connect box/hub. The box has a clear line of sight to the router...no obstructions.
@Taipan70
Can you try disabling Sky Shield
https://www.sky.com/myaccount/bb-and-talk/broadband-shield
Avatar for Taipan70
Thanks for the suggested solution.  I forgot to state that I already have the BroadShield disabled.
