This discussion topic has been answered Discussion topic: Changing to EE broad band 67
Message posted on 23 Feb 2025 07:36 PM
Will be changing to EE broad 67 Will it be easy to set up with sky q and mini box TV
Message posted on 23 Feb 2025 09:01 PM
Once your broadband is connected with EE you should be able to just go in to your Sky Q settings to connect to the new WiFi. I think your mini box will pick it up once the main box has changed but it's been a while since I've had to do that.
Message posted on 24 Feb 2025 07:11 AM
Re: Changing to EE broad band 67
@Johnhaddock the new EE routercwill have to be connected to your main Q box how to do that is explained here https://www.sky.com/help/articles/setting-up-sky-q-connect-to-third-party-router The Q minis have to connect to the main. Q box if using wifi. The Q boxes will no longer act as wifi hotspots as they did with your black Sky hub.
