Discussion topic: Changing to 5ghz and 2.4ghz
This message was authored by V2A This message was authored by: V2A
Hi, I had one great person get me so far in trying to split into 5ghz and 2.4ghz. I switch the synchronised tick box off but still only see one ssid. So got so far and got stuck.
Re: Changing to 5ghz and 2.4ghz
@V2A
Go into the 5ghz wifi settings and just add -5ghz at the end of the existing ssid.  Thats when you will two seperate wifi ssids
@V2A
Unticking the box is not enough. You must rename one of the bands SSID's to something different so you can see both.
I am NOT a Sky Employee
