35
Discussion topic: Changing Sky Hub to different router/modem
This message was authored by bulldog77 This message was authored by: bulldog77
Re: Changing Sky Hub to different router/modem
Hi, I'm in the same position and want to change router. We have fibre to door with 500mps near the router. When about 15ft it away it drops to 30mps so no better than before I upgraded... but my sky router has connection at the back for my landline phone and I can't see this port on any of the other  after market types. Will any new router work with sky q, we have 4 mini boxes and the system has been really unstable since changing to fibre to door. Eveything  is connected wirelessly opposed to any hard wiring.
sorry, probably being thick.... and any help appreciated
@bulldog77
Sky VOIP wont work with any other router, it requires the Sky one. If you need a landline then your only option is to put any router/mesh system you buy into AP mode and connect it to the Sky hub. Or you could just run it in router mode and have double NAT which shouldnt be an issue unless you play online games.
I am NOT a Sky Employee
This message was authored by L-jones This message was authored by: L-jones
@cookiemonsteruk,
Sorry - this may have been answered already...
If I have the ont box like in the picture, does the mean I don't need a modem router and that any router will be compatible to just replace the Sky Hub?
Looking to completely remove the hub and potentially replace it with something like suggested in the original post (TP-Link AX1800).
Thanks.
@L-jones wrote:
@cookiemonsteruk,
Thanks.
Correct, the ont box is effectively the new modem
Those instructions where for someone who already had a tp link modem router however the instructions for a standalone router are
Tp link AX is on latest firmware
IPV6 on (advanced menu option)
Dynamic IP (SLAAC/DHCPv6)
advanced settings: DHCPv6
prefix delegation enabled
DNS address: get dynamically from ISP
IPv6 LAN
SLAAC + stateless DHCP
MAC Clone: Use Default Mac address
The above is called dhcpv6 prefix delegation so you may want to look at routers that also supports sky mer/dhcp client identifier (option 61)
such as the asus rt ax series of similar spec
This message was authored by azz134 This message was authored by: azz134
I have got sky fibre to house but the sky hub they gave me has a very poor Wi-Fi signal in some rooms. Which new router should I buy.
@azz134
For sky fttp via an openreach ont
You can't go wrong with an
Asus rt ax56u
Asus rt ax58u
Asus rt ax68u
Asus rt ax82u
Asus rt ax88u
Asus zenwifi xt8 and the higher xt9 etc etc
These will work either as access points etherneted to the sky hub or as fully fledged routers directly connected to the ont
At the end of the day its down to budget v requirement
@azz134
Also note that if you don't use the Sky Broadband Hub then there's no known way to access the bundled Sky Talk Internet Calls (voice telephony) provision.
Thinking of getting the Asus RT-AX82U if it's an easy plug into open reach box and then ASU's install wizard. Just hopefully the wood range on that router is good throughout the house(3 bed terraced)
This message was authored by PETER11461 This message was authored by: PETER11461
Hi all,
Just a quick question that i am being asked by our it department they are changing the skyhub router for a firewall router and are asking for the broadband username and password. Sky are unwilling to to give this to me any idea how I get this or whether it is needed to change out the router?
Regards Peter
Any such router needs to be capable of presenting generic Sky credentials in the appropriate manner: not all hardware can do this.
This message was authored by Elim+Garak This message was authored by: Elim+Garak
Hello! I am sorry if this is a stupid question. I am a Virgin Media user and I am thinking about switching to Sky.
At the moment, the Virgin Hub is in modem only mode and I use my ASUS RT-AX86U Pro router to manage all the ethernet/wi-fi connections.
I do not need Sky VoIP.
What would be the exact procedure, software side (I know I have to unplug Virgin Hub, plugin Sky and connect the cable from it to my router :-D), that I would need to follow to use the SKY Hub mantaining my own router?
Thank you!
@Elim+Garak
The Sky hub does not have modem mode so to replicate the setup you have at the moment with virgin would depend on what service Sky can provide you with and which package you decide to take
- If you are connected over FTTC (Fibre to the cabinet and then copper cable to your home) then you'll need a 3rd party modem to sit behind your Asus router
- If you are connected over FTTP (Fibre to the premises) and get an Openreach optical modem in your home then you can just connected your Asus router directly to that
@Elim+Garak
How the asus is set up depends on what connection type you can get with sky  superfast fttc, g.fast or fttp
The first 2 require an appropriate vdsl2 or g.fast modem to use the asus in place of the sky hub
With fttp the asus will also work this time directly connected to the fibre optic ont
First of all, thank you both for the answers.
I should have FTTP, or at least that's what I have been told when I got the fibre 3 years ago.
If I check my address on Sky's website, it says that I can get up to Gigafast (900 Mb/s).
@jamesn123 , you said "if you get an Openreach optical modem". Is that some kind of "lottery" or I can ask for it specifically when I contact Sky for the switch?
Finally, I would choose the Ultrafast+ connection with Sky Entertainment & Netflix.
Finally, based on the assuption that I have FTTP and get the Openreach optical modem, what is the procedure I should follow to setup everything?
Thank you so much again to both of you @jamesn123  and @cookiemonsteruk , you are being very kind and helpful.
@Elim+Garak
You would ethernet the asus to the sky hub and sequentially update the asus until it doesn't update anymore
Remove the sky hub and ethernet the asus to the ont and look for client identifier (option 61)  and enter :-
anything@skydsl|anything
And the asus should authenticate fairly quickly
