Discussion topic: Changed to Sky max hub but I am having trouble getting my smart plugs to connect
This message was authored by: SteveR4
Smart plugs won't connect to my Sky max hub. Need 2.4ghz to connect. How can I do this on my hub?
Re: Changed to Sky max hub but I am having trouble getting my smart plugs to connect
@SteveR4
With a white Max Hub you may need to reduce the wireless security level from WPA3-T to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band.
