Discussion topic: Cant log o to Ring door bell or Amazon Echo Alexa
This message was authored by: Bruxism
Hi all.
I'm at my wits end and need you help
I thought moving away from TalkTalk to a Sky broadband would be a breath of fresh air, but after being on the phone for ages to technical and being cut off 3 times I'm not so sure moving over was the right move I cannot set up either my ring door bell or Alexa Echo to the 4.2 router have so far..
Un checked 2.4 & 5 bands
Renamed the SSID name
Soft reset of all devices
Hard reset on all devices
Batteries filly charge
Changed the security settings
 It doesn't matter what I have done so far, but in set up the devices just aren't visible
Any help would be appreiated
Re: Cant log o to Ring door bell or Amazon Echo Alexa
@Bruxism Ring camera since you say you have reset it all, then it's a start from scratch and ideally with the Ring right next to the hub, and do use your 2.4Ghz band ssid.... Ringdoor bell 2nd gen it has been on sky 1st time, ee 2nd time and back to sky 3rd time, never had a problem and going on 4 years now i think smae with the Ring Camera...
Ring device manuals
Alexia afraid your on your own with that one from me, amazon oops!
