Discussion topic: Cant get skybqlis security key to work.
Message posted on 30 Apr 2024 12:50 PM
Cannot get broadband to work du to security key
Message posted on 30 Apr 2024 01:21 PM
Re: Cant get skybqlis security key to work.
What about the security key? What is the issue with it? You need to be more specific.
Message posted on 30 Apr 2024 01:25 PM
Wen I input the security key comes back not recognised i have try but no luck any ideas?
Message posted on 30 Apr 2024 01:28 PM
What device are you trying to connect?
Are you sure you are typing it correctly? The security key is case sensitive & some numbers look like letters & vice versa.
Message posted on 30 Apr 2024 01:32 PM
Yes I know is sensative key I have been very extra careful with it. But no luck
Message posted on 30 Apr 2024 01:39 PM
Try holding the reset button on the rear of your hub for a minimum of 30 seconds then try connecting again
Message posted on 30 Apr 2024 01:42 PM
James tanks very much for trying to help I appreciate
