Discussion topic: Cant connect
Message posted on 06 Aug 2024 12:32 PM
Cant connect
I seem to have internet but when I enter some websites it does not log in. When I try another website it connects without any problems, for example when I try tui.com it takes 40 seconds to connect to the site.
Message posted on 06 Aug 2024 01:02 PM
Re: Cant connect
@Razgrad Have you just joined Sky recently?
Message posted on 06 Aug 2024 01:11 PM
Re: Cant connect
yes 2 weeks ago
Message posted on 06 Aug 2024 02:12 PM
Re: Cant connect
@Razgrad Have you changed the broadband sheild setting in my account under the broadband & talk tab from the default of PG13.
Message posted on 06 Aug 2024 02:16 PM
Re: Cant connect
i havent change anything can you please help me on this matter how i can do it
Message posted on 06 Aug 2024 03:36 PM
Re: Cant connect
@Razgrad If you login to my account and follow what I put in the last reply it should let you change it to see if this solves your issue.
Message posted on 06 Aug 2024 03:40 PM
Re: Cant connect
hi Just i change to the suistable for all ages should be work will see
