Discussion topic: Cant connect to internet. WiFi down
This message was authored by: Ioannis3
No internet in the house. WiFi down
Re: Cant connect to internet. WiFi down
@Ioannis3
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
