Discussion topic: Cant connect to hub from mini box
This message was authored by: xxEckxx
I can't connect to WiFi on mini box in garden room.
Re: Cant connect to hub from mini box
@xxEckxx
Has it ever worked out there?
Avatar for xxEckxx
Yeah has worked fine for a few years. The network (main hub name) has dissapeared with only the network name that you see in network setup appearing as an available network.
I use a TP link hub which goes to a sky booster for the main box and all the mini boxes run from cables. The old sky hub name was that always appeared and still does in the house but no longer shows up as available in my garden.
