This discussion topic has been answered Discussion topic: Canon MG3650S printer won't connect to Wifi
Message posted on 11 Sep 2024 08:19 PM
Message posted on 29 Mar 2025 12:04 PM
Great many thanks for your reply.
Message posted on 13 Sep 2024 12:41 PM
Re: Canon MG3650S printer won't connect to Wifi
Hi @WilkoPaul
I would note that the printer is approaching 10 years old now so its possible it does not like the WiFi 6 features of the newer Sky hub.
You can try and get it to connect by temporarily switching off 5ghz for the router in the My Sky app, then seeing if the printer will connect to a 2.4ghz only signal.
Message posted on 13 Sep 2024 12:43 PM
Hi
Thanks for your reply, how do I turn it off please?
Message posted on 13 Sep 2024 12:49 PM
Go to the My Sky app, go to the Max Hub's settings, click on Advanced Settings, click on the Disable WiFi button, dismiss the warnings that come up and you will see two controls, disable the 5GHz band.
Message posted on 13 Sep 2024 12:52 PM
Fantastic that works, thank you so much.
Message posted on 28 Mar 2025 06:19 PM
Hi. I'm having exactly the same problem with the same printer as upgraded to the max hub this week and have seen your question and answer.
Can you tell me did you enable the 5 GHz again for other devices to connect to once you got the printer to connect to the 2.4 GHz? And did the printer remain connected to 2.4? Hope you don't mind my question, I'm not very tech savvy.
Message posted on 29 Mar 2025 11:43 AM
Hi yes back on 5ghz and it still works ok
Message posted on 29 Mar 2025 12:16 PM
