Discussion topic: Cancelling full fibre order
Message posted on 25 Sep 2025 01:59 PM
Hi
i I mistakenly ordered full fibre and I want to cancel this order.
Message posted on 25 Sep 2025 02:08 PM
Re: Cancelling full fibre order
@Valerie26
l’m afraid you aren’t speaking to Sky Customer Services by posting here. This is a customer led discussion forum where we try to help other Sky customers.
You need to contact Sky asap to cancel the order.
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🟩 📞 Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline. The forum doesn’t allow the display of other numbers. Other official numbers to Sky from the UK are 03 numbers which are normally inclusive from non Sky phones.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
🟩 online help via this link
https://www.sky.com/help
🟩 Sky Assistant 💬 should also be available via
🟩 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note ~ ROI customers 🔹If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
