4
This discussion topic has been answered Discussion topic: Can the full fibre openreach box and router be unplugged for any period of time?
This message was authored by: COOPER551
Can the openreach box and router be turn off (unplugged) for any period of time
Re: Can the full fibre openreach box and router be unplugged for any period of time?
@COOPER551
Yes: you just won't have any internet connection through them.
Conceivably a period of months is not ideal, because then a router might miss two or more successive software updates.
@COOPER551  What do you need it off for longer periods for?
@COOPER551
Avatar for COOPER551
Thank you it would only be for up to two weeks or while work is carried out and the Internet would not be needed at the property.
@COOPER551
If unplugging and removing the ONT, remember that the optical pigtail cable and green fibre jack plug is rather fragile, and needs to be kept free from dust: you definitely don't want it just hanging on a skirting board.
