This discussion topic has been answered Discussion topic: Can the NG Orbi 970 router replace the Sky Max hub?
Message posted on 02 Apr 2024 04:45 PM
Hi all,
I have the Sky gigafast fttp connnection, with poor WiFi signal throughout the house (its a large very old building with thick brick walls).
I was about to order the new Netgear Orbi 970 mesh system, intending to replace the sky hub with the Orbi router.
Appreciate if somebody could confirm this system supports DHCP option 61, and will work with sky broadband (without the hub). The netgear page of routers supporting DHCP option 61 hasn't been updated since 2021.
Cheers,
Gerard
Message posted on 02 Apr 2024 04:56 PM
According to their own blurb
- Orbi works with any internet service provider. The Orbi app makes it a breeze to set up and manage your WiFi
In fact all orbis at 850 upwards do appear to work with dhcp option 61 client identifier. You can also check out asus zenwifi xt8 and above which do work and are quite a bit cheaper but just as capable
Message posted on 02 Apr 2024 05:16 PM
Re: Can the NG Orbi 970 router replace the Sky Max hub?
Hi and thanks @cookiemonsteruk it seemed that way, I just couldn't find anything concrete!
Yes I am indeed also looking at the ASUS XT12 and ET12 systems - will make a decision tonight! Cheers
Message posted on 06 Apr 2024 11:40 AM
I can confirm that the Orbi 970 mesh system does indeed support DHCP Option 61, and connects directly to the ONT (no need for sky hub).
Inital impressions are good , with the wireless backhaul seeming very solid. At basement level (when connected wirelessly to the satelite (which itself is on a wireless backhaul), I am getting 930/106 with iphone 15 pro max, and 790/110 with laptop.
With the sky max plugins i was getting average 50 - 100 down
Message posted on 30 Aug 2025 03:52 PM
Hi, I do have the Orbi 970 and there is an option to set option 61, I have done this by inserting the user name - Anything@skydsl|Anything this is exactly what i have used. My question is there anything else I need to select ie, should I set detection to DCHP AUTO DETECT, PASS THROUGH... Or any other setting?
Currently SKY worked no problem without this setting! Indeed it worked when I simply connected the ONT straight to the Orbi and followed the connection instructions
Than you.
