Discussion topic: Can’t turn on disabled WIFI
This message was authored by: Haven1
Hi I disabled WiFi to control devices but now can't turn it back on. Please help
Re: Can’t turn on disabled WIFI
@Haven1 If you only have the sky Max white hub no choice but to factory reset that one to get your wi-fi back on, hold the WPS button in 10 seconds should do it, think light flashes on it to show it's happening!
Avatar for Haven1
Level 0 icon
Brilliant thank you 😊
