Discussion topic: Can’t seem to connect to WiFi working from home need help
This message was authored by: Barby66
Can't connect to WiFi and working from home. Are there problems in the area. My router showing all connected and test shows no issues? Need help as can't miss work, diary full of clients booked in
Re: Can’t seem to connect to WiFi working from home need help
@Barby66 if the lights on your hub are showing it is connected (https://www.sky.com/help/articles/hub-lights-explained-start) but no data is flowing the recommended fix is to power down the hub for at least an hour to force a reconnection at Sky's end. Alternstively as a temporary fix you could try adding a public DNS service to the network settings on your laptop. Navigate to the the Network settings for the Sky connection find the DNS line set thst to manual and add the following sddresses 8.8.8.8 and 8.8.4.4 which are Google's public DNS service which should enable you to reach the internet on that device.
One note you buy a domestic servicecfrom Sky the fact you use it for business is your choice doesn't change that status  so it is wise to have a fall back plan as in the case of line faults the SLA is a fix 2 full working days after the report.
