Discussion topic: Can't order sky wifi max router
This message was authored by: Grimmy095
Hi I've been trying for a couple of days to upgrade my router to the wifi max router but everytime I try and place the order I'm met with a web error
Re: Can't order sky wifi max router
@Grimmy095 where that happens call Sky to place the order
This message was authored by: Ed84
Have you had any luck? I've been trying to upgrade too as our wifi constantly drops and is so slow!
Avatar for Grimmy095
I ended up just ringing them but the pricing was different once I rang up... £8 a month when it's advertised as £4 on here. But the wifi is definitely better and you get a wifi pod with that u can put whever your wifi signal is lacking.
