Discussion topic: Can’t find date to activate my up grade hub
This message was authored by Christina29 This message was authored by: Christina29
I received upgrade sky hub but can't find the activation date on box
Re: Can’t find date to activate my up grade hub
@Christina29
What hub did you receive.?
Did you receive it due the old one no longer supported or due to an upgrade in speed?
Christina29
Old one due to it being no good in December 2025
@Christina29
If its a straight swap and you're still on the same broadband package then you should be able to plug the new one in right away
@Christina29
As @cookiemonsteruk has said this is just a straight swap so there is no activation date so you just need to plug it in and then setup your wireless devices again using the new network name and password key as supplied on the small card that came with it.
