Discussion topic: Can’t connect tv to wifi
This message was authored by: Rose92
Tv can't connect to network and lightning hub flashing and staying amber
Re: Can’t connect tv to wifi
@Rose92
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Avatar for Rose92
Level 0 icon
No errors found on test, called and they found error but told me to do test which says no errors. Amber light not turning green
