Discussion topic: Can’t connect to work VPN on black sky router hub
Message posted on 25 Sep 2024 09:20 AM
I have the black sky Q router hub and I an unable to connect to my company's VPN over Wi-Fi. All my other devices connect with any issue. But when I try and connect to Wi-Fi on my laptop I get a message that says "no internet, secured". I can connect via a phone hotspot. I connected my IT department who checked all the devices settings and confirmed they are all ok. I can connect to Wi-Fi when I in the office. So this confirms that the Wi-Fi settings do work. I called sky and was told to add the VPN address to my exceptions list on Broadband Shield, which I have done. But again I can't connect to Wi-Fi on my laptop. There are a few messages about router settings, but I am getting mixed messages when I call sky. All I need is what setting to change and where so I can connect. Thanks
Message posted on 25 Sep 2024 09:31 AM
Re: Can’t connect to work VPN on black sky router hub
This could be caused by Sky using MAP-T on your line. The quickest way to solve is to enable UPnP on your Sky hubs settings.
Message posted on 25 Sep 2024 09:41 AM
@jamesn123 Sky cannot use MAP-T on the black hubs as they do not have the necessary support built-in. It is only used where the routers advertise support for DHCPv6 Option 95 which includes the white Sky Max hub and some third party routers.
@Paul_B while enabling UPnP wont hurt it shouldn't make any difference. Can you post which VPN software your company is using?
Message posted on 25 Sep 2024 09:42 AM
Ah yeah didnt see it was an older Sky hub. Just saw VPN and assumed it was the issue that 99% of the forum seem to be having at the mo
Message posted on 25 Sep 2024 09:45 AM
@jamesn123 no issue. If you want an oddity the Ubquiti Dream Machine is a right pain it says it supports DHCPv6 Option 95 but acrually doesn't. Apparently its been like that for 8 years! 😀
Message posted on 25 Sep 2024 09:57 AM
I'd say thats pretty in keeping with Ubiquiti gear in general really 😂
Message posted on 25 Sep 2024 11:33 AM
It's vpn.nationet.com
