Discussion topic: Can’t connect to wifi
This message was authored by: Cat54
Not able to connect to wifi, but when I've done a signal check it states there are no issues or faults
Re: Can’t connect to wifi
@Cat54
Any engineer visit that’s required is still likely to be delayed due to the disruption from the recent storms.
For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
