Discussion topic: Can’t connect to wifi
This message was authored by: Nikd1
Message posted on 28 Oct 2024 02:04 PM
My phone can't connect to my broadband but it can connect to the broadband that I used to have?
Find out more
Message posted on 28 Oct 2024 04:33 PM
Re: Can’t connect to wifi
@Nikd1 if other devices are connecting properly and you have checked you are entering the password on the Sky hubs label correctly then tell the phonecto forget the connection. Power the phone down fully and then reboot it once it's fully back working try connecting again.
