6
This discussion topic has been answered Discussion topic: Can’t connect to network on sky even though tv is connected. Screen frozen on searching for local ne
This message was authored by: Hilmack
Screen is frozen on searching for local network and back up to cancel which it won't.
This message was authored by: Highlinder Answer
Re: Can’t connect to network on sky even though tv is connected. Screen frozen on searching for loca
@Hilmack  Have you tried to switch the box off and on then go to the network menu to do the connection manually?
@Hilmack  Has this TV been connected to this router before and are you new to Sky?
Avatar for Hilmack
Level 0 icon
It has but we have just been sent a new card
@Hilmack  what is the card for?
Avatar for Hilmack
Level 0 icon
Sky+ box
Avatar for Hilmack
Level 0 icon
Thanks so much that has worked. You're a star! 👏
