Discussion topic: Can't connect to my broadband
This message was authored by: Danedney
Hi I can't connect to my broadband an it's been on since this morning
Avatar for Danedney
Level 0 icon
Re: Can't connect to my broadband
I mean it's been off since this morning qn stilll cant connect
@Danedney Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
