Discussion topic: Can’t connect to Broadband
This message was authored by: MichelleRandel
I am having trouble connecting to my broadband
Re: Can’t connect to Broadband
@MichelleRandel
Are you saying your broadband isn't working, if so then the first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Avatar for MichelleRandel
  • I have run tests and it says that my home set up is not working?
