6
This discussion topic has been answered Discussion topic: Can’t connect sky broadband to Tv
This message was authored by: MaryD1234
Hi, I have just connected sky broadband to my TV and it doesn't work, the broadband  speed checker says it is good. Have turned off and on but have 'unsuccessful connection' Anyone else had this issue? I have sky stream,
Avatar for MaryD1234
This message was authored by: MaryD1234 Answer
Re: Can’t connect sky broadband to Tv
Thank you, it is working now.
Mary
This message was authored by: Mark_Jabez
Just Re-set the broadban Hub, and then reset your Netowrk on the TV. Will start working.
in case if it doesnt your, Just reset the settings on the Hidden Settings ( Highlight settings and press 001 Sellect) .
Mary
This message was authored by: Kay365
For a week now I have had no broadband connection for my sky tv.
I have followed all the trouble shoot routes but nothing has changed.
on my settings menu it won't allow me to reset my WiFi as it doesn't give me that option I just have a message constantly on my screen.
I have tried to follow the instructions but it just keeps saying it can't connect.
@Kay365
Have you tried rebooting your broadband hub at the mains by turning it off, waiting a few minutes then turning it back on ?
Yes I have tried it all but now my WiFi isn't working.
@Kay365
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
