Discussion topic: Can’t connect printer to wi fi
This message was authored by: Eve223
Hi, any help out there? I cannot get printer to connect to wi fi. Directed to settings and everything seems to be fine.
Re: Can’t connect printer to wi fi
@Eve223
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
