Discussion topic: Can’t connect my phone to wifi from bedroom
Message posted on 08 Apr 2025 12:02 PM
The otherday it would t connect even though it could see the broadband today it can't even find the wifi from my bedroom
Message posted on 08 Apr 2025 01:58 PM
Re: Can’t connect my phone to wifi from bedroom
@Mincher Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
