Discussion topic: Can't connect my devices
Message posted on
13 Mar 2024
09:18 AM
- last edited:
14 Mar 2024
08:43 AM
by
Kelsingra
No internet to any devices.
Moderator note: Changed title to reflect topic more.
Message posted on 13 Mar 2024 09:20 AM
Re: No internet
What colour are the lights on the sky hub
Message posted on 13 Mar 2024 09:21 AM
Re: No internet
All yellow however the LAN light on wall is flashing
Message posted on 13 Mar 2024 09:27 AM
Re: No internet
Could you use the service checker in your my sky app using 4g/5g mobile data and see if it lets you book an engineer
Message posted on 13 Mar 2024 09:45 AM
Re: No internet
No - it's telling me everything is ok however I have no internet connection
Message posted on 13 Mar 2024 09:50 AM
Re: No internet
@ChayB the flashing green LAN lightbon the ONT is normal. However if you have no connection you need to report the issue to Sky but it is probably wise to reboot the Sky hub by removing the mains power for 30 seconds as that van restore connections.
Message posted on 13 Mar 2024 10:09 AM
Re: No internet
I am having the same issue, everything is showing ok online but I have no internet
Message posted on 13 Mar 2024 10:13 AM
Re: No internet
I have the same issue. The tests say all ok but I have no internet. A hard reset of the router (hold down button at back for 30sec) sorted it for 5 minutes but it's gone off again. Seems impossible to actually speak to anyone at sky because the tests say it's fine.
Message posted on 13 Mar 2024 11:01 AM
Re: No internet
I'm having the exact same issue.
