19 Jan 2025 03:33 PM
Hi there,
I have Sky Fibre (FTTP). My Sky router is connected to the Openreach ONT. I'd like to completely replace my Sky router with a different one if I can.
Can I use any router with Sky Fibre or does it have to be a router that supports DHCP Option 60/61?
Any advice would be greatly appreciated.
19 Jan 2025 03:41 PM
80% of the time any router can authenticate via dhcpv6 prefix delegation. To guarantee connection it would be advised to get a router that has dhcp option 61 client identifier.
We find the asus rt ax and asus zenwifi routers to be more consistant in authenticating both at the same tie
19 Jan 2025 03:43 PM
Look at the asus rt ax58u as minimum spec
19 Jan 2025 04:11 PM
Thank you for your reply.
I recently purchased a Linksys WiFi 6 Mesh Router which asked me for my ISP settings (username and password)
I wasn't sure what this info was or even where to find it. Do all third party routers require this info?
Thanks,
19 Jan 2025 04:16 PM
Not sure what format the linksys requires the string to be in
But the format is
Do you have a screengrab on the various isp settings?
19 Jan 2025 04:34 PM
I returned the router to the retailer.
Currently I am using the Sky router provided, as I wasn't sure which router to go for before I try buy one and try again with a third party router.
19 Jan 2025 04:38 PM
My own one is the asus rt ax58u which i would recommend. Others here have the asus rt ax88u and the asus zenwifi xt8
19 Jan 2025 04:57 PM
Ok, I might have a look for that router then. Is it pretty much plug and play or does it need a username and password?
19 Jan 2025 05:03 PM
For the asus rt ax58u the firmware needs updated until it doesn' update anymore.
After that change connenction type to automatic ip. Locate client identifier (option 61) field and enter anything@skydsl|anything
Remove sky hub and ethernet asus to the ont
19 Jan 2025 05:06 PM
19 Jan 2025 05:09 PM
That should work fine 👍
19 Jan 2025 05:33 PM
Thank you for your help!
19 Jan 2025 05:35 PM
If you do get it come back here for further assistance if needed
20 Jan 2025 08:45 PM
Hi again,
I bought the router. I have connected it up to my ONT modem. I'm now in the app trying to set it up and I'm not sure what to do/what to select.
20 Jan 2025 09:37 PM
Best to use the web interface 192.168.x.y not the asus router app. Once the firmware is updated change connection type to automatic ip and enter client identifier (option 61) string of :-
