6
This discussion topic has been answered Discussion topic: Can I use a broadband dongle to get a signal out in the garden?
This message was authored by: usedmodel
I can't get a signal out in the garden and just read about broadband dongles, would this helpme get a signal?
Avatar for usedmodel
This message was authored by: usedmodel Answer
Re: Can I use a broadband dongle to get a signal out in the garden?
Hi, thanks, I want to use a desk top in a summerhouse about 20m away, my router is in the lounge, I get a signal outside for about 10ft then it goes.
I would need to buy a dongle if it going to work out.
@usedmodel
What size of garden and what area of it do you actually need to cover with wifi?
And what devices do you wish to use outside?
@usedmodel
You may be misunderstanding the concept: a 'dongle' (most likely a USB wireless adapter) makes a desktop capable of WiFi reception, but only within range of an existing signal.  It does not increase the power of that signal so that it can reach somewhere not already covered.
Thank you very much.
This message was authored by: Robb0
You could use a Powerline adapter to link the router to your desktop in the summerhouse.
@Robb0  That is only possible if the house and the sumer house run off the same consumer unit.
