12
This discussion topic has been answered Discussion topic: Can I buy a Max router?
This message was authored by: Chigirlx
I have ultrafast and wanted to buy the Sky Wifi Max router. Can I do that?
This message was authored by: cookiemonsteruk Answer
Re: Can I buy a Max router?
@Chigirlx
It is loaned to you for around £7.50 pm for the first 18 months then £10 pm
@Chigirlx
Avatar for Chigirlx
Level 4 icon
A lot extra to pay per month. Is it really worth it. I get wifi where I want it just some streams with dolby atmos it buffers and just won't carry on playing. Would a booster make any difference?
@Chigirlx
New Ultrafast connections now get the Max Hub as default hardware, but not the rest of the Max bundle (including loan of pods) unless they add the WiFi Max subscription.
Avatar for Chigirlx
Level 4 icon
I only upgraded recently to ultrafast and didn't get it but I don't want to pay monthly for it. It's only a few streams that don't play. If I get a booster online do I have to have a subcription for it to boost the wifi?
You wouldn't be able to use a Max pod because the only legitimate source for those is on loan from Sky with a Max subscription.
Non-Sky 'booster' (actually range extender / relay) hardware may help.
Avatar for Chigirlx
Level 4 icon
What about a sky Q booster would that work? It's my amazon fire cube I'm trying to get better wifi on
EDIT: I see it would only work with a sky product so that's not going to do my amazon box. Can I ask is the SR203 I was sent wifi 6? If so I'll change my fire box to the newer and that may help
No, the Max Hub is the first Sky router hardware specified to WiFi 6 (802.11ax)
The Sky Broadband Hub and Q Hub are 802.11ac ('Wifi 5' although no-one calls it that ; )
Avatar for Chigirlx
Level 4 icon
Thanks. No point changing my deicce to the newer one then. I'm already obviously paying a lot more for the ultrafast per month so can't really afford extra on top for the Max just to boost a few streams.
This message was authored by: SameOld
I picked one up on eBay to replace my old Sky Q hub (i'm on the superfast package). This will work ok, right?
This message was authored by: daveNOS
@SameOld You should return it and request a refund, the hubs remain the property of Sky and cannot be legally sold.
Canceled it just now.
@SameOld Sky are in the process of replacing the flat Sky Q hubs with the black Sky Broadband hub which is a distict improvment so if you wait until they contact you you will get a new hub at no cost. For superfast the white hubhas minimal advantages and possibly a disadvantage as it does not allow Q TV boxes to act as wifi hot spots if you have any of those
