Discussion topic: Buffering on Sky stream with Sky fibre
This message was authored by: Seashell10b
Message posted on 13 Sep 2024 06:52 AM
Since upgrading to Sky super fast ultra plus fibre the WiFi signal is extremely poor and causing buffering with Sky stream(which is located less than 2m from the hub). I've connected with Ethernet cable and it's fine.
Will it be a hub issue which would be sorted with a replacement? Don't particularly want a cable running across the living room constantly!
