Discussion topic: Broadband three greens but no connection
This message was authored by G+Curley This message was authored by: G+Curley
Last night broadband dropped. So did the usual switch to on and off. It worked fine for a couple of hours. Now it hasn't worked all day. Three green lights on the router and devices appear to be connecting but nothing is happening.
Any advice?
Phone line is clear so filter is ok.
Re: Broadband three greens but no connection
@G+Curley  What error message does it give you when you try to browse the Internet?
@G+Curley if its still not working today reboot the hub by unplugging the power for a couple of minutes which may well cause the connection to be restored.
If still stuck give Sky a call cheapest way to do thst is tondial 150 on your Sky Talk line.
This message was authored by LGUser This message was authored by: LGUser
But if the connection to the Internet is not working, the phone line is probably not working.
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
User has the 'phone connected to a filter so not internet calls. Very possible for a 'phone to work and have an issue with internet (OP also states phone line is clear)
"Sometimes, the only choices you have are bad ones, but you still have to choose"
I missed that bit. I stopped after the last question asking for advice.
