Discussion topic: Broadband test saying connection ok but last tested 8 hours ago & not updating all devices dropped
This message was authored by: Hollag
Router intermittently showing 1 light sky test showing all ok but test shown as done 8 hours ago and not updating
all devices in house appear to have dropped connection
Re: Broadband test saying connection ok but last tested 8 hours ago & not updating all devices
@Hollag
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
