Discussion topic: Broadband speed very slow
This message was authored by: Jmacmillan24
Message posted on 24 Jul 2024 07:03 PM
I carried out an independant speed checker and it states 8.21 download speed. I am supposed to be guaranteed 15.2!!
This message was authored by: JPR007
Message posted on 24 Jul 2024 08:31 PM
Re: Broadband speed very slow
@Jmacmillan24There isn't usually much credit in most so called "independant speed checkers" - plus they measure something different to what the ISP tests do.
How is the device connected that you are running this test on?
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
