Discussion topic: Broadband slow since the 24th
Message posted on
28 Sep 2024
03:18 PM
- last edited:
30 Sep 2024
07:58 AM
by
KevNewMedia
Hey all,
Can you please advise on the below. I am on a ultrafast plus contract which is 500mb download and 30/50mb upload. Since Tuesday the upload hasn't went above 0.01 and is usually at 0.00. I called sky and asked for an engineer to be sent out but they sent a new router. The new router arrived and the same issue persists. I called again today asking for someone to be sent out and they are now sending out a booster instead of a engineer. I have been with sky for nearly 12 months on FTTH and never needed a booster in the past. Can you please look at the stats and see if you can spot what the issue might be. The router stats won't even pull back a connection speed since Tuesday. More often than not since Tuesday I can't even open the speedtest.net side nevermind run it. Thanks in advance,
Moderator note: personally identifiable information removed
Message posted on 28 Sep 2024 08:21 PM
Re: Broadband slow since the 24th
Hello @DarrenW1
All the stats show is that your connected by 5ghz WiFi.
Can you connect to a laptop or computer with a ethernet cable, and run the speed test again.
Message posted on 29 Sep 2024 05:57 PM
Hey @Metis,
Below are the results I get when my laptop is directly connected to the router with an ethernet cable.
Message posted on
29 Sep 2024
06:03 PM
- last edited:
30 Sep 2024
08:00 AM
by
KevNewMedia
Message posted on 29 Sep 2024 06:46 PM
Was your problem ever resolved? I am having the same issue, 2 or 3 days now. My computer is so slow that it took 2 minutes to load Sky help and it takes hours to download a single file. Any advice from tech team?
Message posted on 01 Oct 2024 02:56 PM
Hey all,
Does any one have any further suggestions on what to do. Sky sent out a booster and it is connected up but the issue is worse than ever. Sky have now sent out a new router and a booster and I can't even load up a speedtest to complete whether I am connected directly to the router or on the WiFi. Issue is now going on for 8 whole days.
