Discussion topic: Broadband signal loss
This message was authored by: JesP1
Every night the broadband cuts off or the signal is very poor at 10 ish
Re: Broadband signal loss
@JesP1 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
