Discussion topic: Broadband router randomly reboots
Message posted on 15 Apr 2024 11:43 PM
Message posted on 16 Apr 2024 06:27 AM
Re: Broadband router randomly reboots
@rallyfan1986 if the hub is randonly rebooting and it isnt being caused by a poor power connection Sky normally will swap it out. I am escalating your post to the Sky team who support the forum who should be in touch soon to offer you a private chat session to get this sorted. Keep an eye onnthe forum as if you miss the message just click the chat icon which will be added to the forum pages for you to use.saving a long phone call.
Message posted on 16 Apr 2024 09:48 AM
Thanks for escalating this. We’ve sent an invite to @rallyfan1986 to chat.
Message posted on 03 May 2024 01:33 PM
The router has been repalced however the problem still exists. The router lights will go off, with just the first light being solid red, the other lights will then turn on (green).
The internet is offline for around 2 minutes until the lights are back on, there is no issues with the internet other than these drops
Message posted on 21 May 2024 09:19 AM
Following up on this, I am still seeing the same issues.
The internet will drop out with only the first light lit up red, this will then go green, with the other lights going orange and eventually turning green after a few minutes
Message posted on 07 Jun 2024 09:57 AM
Further following up on this, the problem still persists, with dropouts on:
21/05/24 09:10
21/05/24 10:00
22/05/24 09:29
25/05/24 07:38
28/05/24 09:20
28/05/24 12:06
27/05/24 07:02
05/06/24 11:01
07/06/24 09:45
Message posted on 30 Oct 2024 11:13 PM
Did you ever get this sorted as I have the same issue, thanks
Message posted on 30 Oct 2024 11:30 PM
Yes, it ended up fixing itself. All I can guess is sky identified an issue at their side and fixed it
Message posted on 04 Oct 2025 07:50 PM
hi @Chrisee I am also facing the same issue, my router disconnects around 2 times each day and then kind of reboots which nearly takes 2 minutes before devices reconnect. I have tried the tricks like rebooting, resetting the router, used a different switch but nothing seems to be working.
