Discussion topic: Broadband repeatedly dropping out
This message was authored by: Midds1
For the last 5 days, our broadband repeatedly drops out. I rang Sky on Thursday evening and was advised an Open reach engineer would be in touch. We are still waiting. When I test the broadband on the Sky website, the results say everything is OK. It is not. The main hub has an Amber light labeled 'internet' which flashing and solid Amber. Every hour or so, it reconnects, then drops out after a few minutes. Please advise.
Re: Broadband repeatedly dropping out
@Midds1
If you reported the issue does anything appear here for you:
https://www.sky.com/ordertracking
If not try running the line test here to see if any faults are found:
If this is of no help give Sky again for an update.
