9
This discussion topic has been answered Discussion topic: Broadband problems and no Fibre broadband available
This message was authored by: Irid
Hi, My current broadband isn't adequate- weak signal except when close to the server, drops out regularly and tv buffers. I am moving to Sky as the call centre says that their TV option will reduce the load on the broadband , resulting in better internet performance. The sky TV guy came to fit a Q box today, but couldn't as i dont have a satellite dish (does anyone have a satellite dish nowadays ?) My broadband is being switched to Sky in 2 days time. The basic problem is that i have an old ADSL cable supply with no option to change to fibre. So won't this be the same poor broadband as my current provider?
This message was authored by: Highlinder Answer
Re: Broadband problems and no Fibre broadband available
@Irid  Going by the screenshots you can get superfast broadband and this is much faster than ADSL.
@Irid  Can you please fill in the form in the link below and post a screenshot after you have submitted the form. Making sure not to include the private information in the top-left corner please.
If ADSL is the only service available at the address then yes, broadband from any ISP can only be equally poor.
Some tens of millions of properties in the UK have had satellite dishes installed over the past three decades: Sky access online through the Glass/Stream platform has been around for less than three years.
Avatar for Irid
Hi Highlinder
I have taken two screenshots. How do i attach them to this post? Apologies if this is a dumb question
Avatar for Irid
Avatar for Irid
Avatar for Irid
Many thanks. Thats very helpful
@Irid
And the predicted speed is close to the maximum for the technology (80/20Mbs) which suggests the fibre cabinet is within a few hundred metres of the address.
