Discussion topic: Broadband outage 26/03/25
This message was authored by: Sheriscott
The WiFi has been on and off since last night and now won't come on. The hub flashes oranges, goes blank and then flashes orange again
all tests say there's no issues, but the hub is saying otherwise and we have no internet/wifi
Re: Broadband outage 26/03/25
@Sheriscott
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
@Sheriscott
