Discussion topic: Broadband outage 20 April
This message was authored by: Liz147
Great - another broadband outage in mid Devon. Service was down for 5 days before Easter, now it's down again.
It's not good enough to say 'these things are usually fixed in a couple of days' on the service checker webpage, and provide no way to find out from a human when it will actually be fixed.
Come on Sky, you can do better!
Re: Broadband outage 20 April
@Liz147
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault affecting multiple households.
